DTWC has passing point system now
  • t3r3e3
    • 1962
    Originally posted by bradc View Post
    hope they got the creek sand good and wet if it slicks off prp is awful
    Never understood why they couldn't get some better clay. Before the know it alls throw the flooding nugget out there, realize that clay has a smaller pore size than silt. Silt is what the river deposits when it floods. Good clay should hold up well, and in theory, all the silt should be long gone by the time the big fall shows roll around. Either way, if the track slicks off the train race will commence.
    We'll miss ya Doc Watson...
    • 71PRPFan
      • Jul 2010
      • 943
      They put clay on it every year it's not pure river dirt
      04192016
      • GEAR_HEAD
        • 3107
        Originally posted by t3r3e3 View Post
        One and two are usually rough around the bottom. Which is a problem seeing as how the big shows often turn into catfish races around the uke tires. The last Lucas show was pretty good though.
        I was talking about the fact that they can't use the entire track in 1 and 2 because of the shelf at the top. If they could run from to bottom like they were at Florence it will be a great show.
        • Bubstr
          • 3734
          What I've seen, is a poorly prepared track is going to have a stinker of a race, no matter what format is used. One other thing I've noticed is, when you have passing in the heat races and don't have the single groove thing, from time trialing, when the track slicks off and gets black, it does it from top to bottom. This cuts the odds of single lane rubber down track.
          I love the passing points format and if there was one thing that needs improved on it, it would be announcing the intricacy of the points counting to the fans in the stands. Racer A won 98 points for second and 12 points for passing. That gives him 110 points. Racer B won the heat for 100 points, but got no passing points. Fans like to know what is going on. They also like to know, how the starting spot draw works and how it's shuffled for second heats.
          • deez lug nuts
            • 137
            Give out passing points info at the ticket booths/concession stands.
            • huskerdirt
              • Mar 2011
              • 5620
              http://florencespeedway.com/drivers/...ts-procedures/
              • t3r3e3
                • 1962
                I started to type something about the ledge/shelf, but then deleted it. My best guess is the track folks realized about 2/3 of the way through shaping the corners that the racing surface was going to exceed the height of the walls, or close to it. Thus, they quit shaping the top at a similar banking to the middle. Either way, most nights the top 1/3 of the track just sit there unused. If they fixed them, it would be more like Lawrenceburg, which is a racy joint.
                • GEAR_HEAD
                  • 3107
                  That can be fixed in a day or two. If the walls aren't high enough then the middle and bottom can be dug lower. Tracks with shelfs are irritating because it's easily fixable. Eastbay, wayne county, roaring knob, eriez, and PRP all have ridiculous shelfs thay take the high line away. Florence has their track right, they were using every inch of the place all weekend.
                  • deez lug nuts
                    • 137
                    Post that webpage address on concession stands and ticket booths.
