Need computer help
  • hustler t4
    • 421
    Need computer help
    Anyway to stop buffering on dod videos. Any settings I can adjust or any help be appreciated.
    Thanks
  • GA-DIRT
    • 765
    Get a 3rd grader to help you out😇
    • hustler t4
      • 421
      Since you in 4th mayb you can help
      • davis2902
        • 527
        Whats you internet download speed?
        • TALON75
          • 887
          Use Speedtest on all your devices with our free desktop and mobile apps.
          You can try this to find out your download speed.
          www.RACE91.com
          • formercrewguy
            • 987
            Originally posted by TALON75 View Post
            http://www.speedtest.net/
            Heck....an old Rayburn swing arm car is faster than MY broadband!
            • Bubstr
              • 3734
              Sounds like your download speed is slow, just click the HD on the screen and it should work fine. (HD off)
              • old fan
                • Jan 2016
                • 4191
                are you using a full screen or mini screen , you can also check the setting or dpi I believe start on the lowest speed first and .t could a lot a traffic on your ISP side
                • MRM
                  • 3014
                  If you're internet speed is slow, load the video, put it on pause until most of the video has loaded. You can tell that by that bar that goes to the right as it's loading.
                  MRM Racing Photos
                  MRM Racing on Facebook
                  MRM on Twitter
                  • SnakeX3
                    • Sep 2014
                    • 368
                    This may seem obvious, but after the commercial for each DoD video there will be a box in the top right corner that says "HD Is On" or "HD Is Off". If it says it is on, click on the box and it will turn the HD off. That should help with the buffering problem. I should mention that some of the commercials before the videos buffer with a slower internet speed and there is nothing you can do about that. If turning the HD off doesn't help then try what MRM suggested and just pause the video until it has loaded most of the way and then watch it.
                    • hustler t4
                      • 421
                      Thanks to all of you I did all the above and got it working great.
                      Thanks again,
                      hustler
