How to contact administrator/moderator for help
  • Aces&Eights
    • Apr 2016
    • 237
    I made a mistake when registering and need to correct my date of birth, should've been 1975. Also I get an error message every time I log in saying something about missing tokens... How do you post multiple paragraphs? Whenever I type and use a space between paragraphs, whenever it posts it runs it all together. Same with my signature, I wanted them over the top of each other and they are side by side... I clicked on "Contact us" but it tells me they have deactivated email, so I have no clue how to contact anyone for help.
  • GotDirt1313
    • Sep 2013
    • 207
    when you find out, let me know please
    Barbecuebich.... the main cause of diarrhea!!!
      Clayton Wetter may be able to help you out with some of your problems
      • Cardirt0
        • 5271
        This works: hit enter
        Then start new P: hit enter
        3th P graf....
        or just hit enter and dont use dots I hit enter
        and start tiping once more....
        Hitting enter moves you down 1 line....
          • 2020
          3th P graf....
          Just so you know, there is a setting that can get changed that makes it impossible to separate text by hitting enter. It happened to me, couldn't make a paragraph no matter what I did. You have to go into setting and change something I can't remember what it is now, but it's his setting that are causing it not him.
            • 2020
            Think I found it.
            go here: http://www.4m.net/profile.php?do=editoptions
            Scroll down to this part
            Miscellaneous Options
            Message Editor Interface:
            Enhanced Interface - Full WYSIWYG Editing
            Basic Editor - A simple text box
            (use this one) Standard Editor - Extra formatting controls
            See if that don't fix it for your browser or device your using
            • BTExpress
              • Sep 2015
              • 1215
              I Think I found it.
              Billet, Thank you I was having the same problem.
              • GotDirt1313
                • Sep 2013
                • 207
                it
                worked
                thank
                you
                • Aces&Eights
                  • Apr 2016
                  • 237
                  Yes
                  It
                  Did
                  Clayton Wetter set me straight with a PM, but thanks for the input.
                    Yes
                    It
                    Did
                    I figured he could help you out. He seem pretty godd at this kind of things
                    • Cardirt0
                      • 5271
                      They all was have too make it hard.. Spent 5 hour once finding the place to fix something just like this .. I think they do it and lol...
