Stupid Question: Why is tire doping illegal?
  • bullring
    • 947
    What's the purpose of it?
  • old fan
    • Jan 2016
    • 4191
    • bullring
      • 947
      I can see Hoosier's point. I just have a problem with having a rule on something that can't be checked at the track. Kind of sucks for a fan if they go to a race and then a few weeks later the results are changed.
      • old fan
        • Jan 2016
        • 4191
        yes it does same goes when they do heavy teching after the event not so much for lates though but mods they can
          You saw the same entertainment either way. Kinda like watching a play and the actor's check bounced on Friday.
            The idea is to keep people from using dangerous substances, save racers time on tire preperation, and level the playing field in that aspect of the sport.
            • old fan
              • Jan 2016
              • 4191
              HOT ROD is “where it all began,” as the first magazine to cover the hot rod culture. Since that time, HOT ROD has evolved into a brand devoted to everything from hot rods to restomods, barn finds to project cars and everything in between.
              • MRM
                • 3017
                Breathing in huge amounts of that stuff will do some serious damage to a person's health.
                MRM Racing Photos
                MRM Racing on Facebook
                MRM on Twitter
                • heinen81
                  • Aug 2012
                  • 205
                  Tire prep rule, in my opinion, hurts the little guy. First, not all tire preps are softeners. Many are conditioners that bring the tire up to temp faster, and allows the tire temps to plateau and level off, many times adding life to the tire by better controlling temps. Fact of the matter is fans see a better show, competitors (especially the budget guys) have increased tire life, and the correct preps may allow some of the smaller budget teams to bring some of their tires back to life, versus needing 6 new tires to run a touring show and be somewhat competitive. Generally speaking, preps are fairly low cost, especially if it gives your tires an extra night or two of life.
                  • old fan
                    • Jan 2016
                    • 4191
                    Exactly I wonder how much is sent in the air from dust and what affects will it cause
                    • allthegoodnamesaretaken
                      • Jul 2012
                      • 22
                      Who cares about tire juice being harmful? Cause gasoline, race fuel, carb cleaner, brake cleaner, brake fluid, hot smoldering rubber etc. isn't harmful? I'm not defending juicing the tires, but I think everything I just listed is known to the state of California to cause cancer. Lol
                      • old fan
                        • Jan 2016
                        • 4191
                        California is a cancer and you can take that to the bank
                        • redfred
                          • May 2010
                          • 154
                          What this does is make it more expensive to run these races. The little guy who runs tires a couple and washes them in between nights will get caught up in this if he uses Simple Green or some of the other cleaners popular with racers.
                          I agree, that the intentional act of juicing tires should be against the rules, however there should be leeway for tires to be washed and used again.
                          • old fan
                            • Jan 2016
                            • 4191
                            water sounds pretty good its a known fact that simple green softens tire it has for years
                            • Cardirt0
                              • 5271
                              LOL Make you hope the movie thing happens for real and it falls off in to the Sea....
                              How do you send back 1 million people that dont belong here..Earth Q...
