I run about 12 gallon of fuel for hot laps, 10 lap heat and 20 lap feature. That equals $20.28 per night in fuel. It runs just a tick warmer than alcohol but a bunch cooler than gas. I ran gas for years. My burn off is around 6 gal for a feature. It burns about 33% more than gas but 67% less than alcohol.
Race fuel for2016
What kind of engine are you running 4time? Is it a crate, or an open motor? I have been wanting to try E85, but have heard horror stories about the mixture. What do you do when it is early in the year, and you are getting E70? Is there a place that you can get pure ethanol to bring the mixture back up to E85? Just curious.
I am running an open 404 cubic inch motor with CNC ported heads static compression is 13.6 to 1. I had absolutely zero problems from the start as I said earlier call Patrick at Pro Systems he will walk you through it, he is no more expensive than anyone else I believe the carb was $780. I run a good mechanical pump (clay smith the inventor of the six valve pump) with a dead head regulator at 8lbs pressure no bypass. I get 110 gal at the end of the year and put in the heated garage for the next spring and by the time it is gone the good stuff is back the 1st of May.Originally posted by HEAVY DUTY View PostWhat kind of engine are you running 4time? Is it a crate, or an open motor? I have been wanting to try E85, but have heard horror stories about the mixture. What do you do when it is early in the year, and you are getting E70? Is there a place that you can get pure ethanol to bring the mixture back up to E85? Just curious.
stock car I am running because of cost the way I figure it if I have a bad night my brother and I pit pass at 30 each with $20 dollar of fuel I break even. it pays $75 too start. But all that aside it is a very good fuel for what I am doing and the cooling is zero problem for me too I run a double pas radiator and have two rows of tape to keep it at 190 it runs the best there.
Call him if you don't believe me have no reason to lie and IF you tell him exactly what you have down to cam heads intake headers and such you will not touch it when you get it home he IS that good. Murder Nova, Big Daddy and the Crow car all run his carbs. Oh and they perform he owns more world records with his stuff than any other carb manufacture. Bloomquest has run them as well as Owens but those guys change to whoever will give them stuff and he wont do it. Patrick is a fluid engineer from MIT and he races also Drag and SCCA although he is hurt right now he had a bad crash in his Camaro.Originally posted by stock car driverSo you have two carbs? a gas carb and a e85 carb? 780 for a built carb? That guy should be real busy if they perform, a box stock hp is about that price.
Yes I have the exact same carb in gas and alcohol and E85,have been running the exact same combination for probably 15 years. I have been using his stuff since 1998. He builds all his own metering blocks also no revamped crap. Mine are a 4150 main body blank. Patrick is a racer for the racers and he knows his stuff, I have never so much as adjusted the idle air on mine when I get it back from him and I know if I ever have too something is wrong. Back to the E85 I think for sure if you like gas you will love E85 it is the best of both worlds and will also save you a ton of money.
You are off on burn off it is only 33% more than gas and 67% less than alcohol. I never mix fuel it is absolutely not necessary not even for bracket racers but hey each to there own I wont ever change back for sure not for Saturday night 20 lap features. All of my fuel here in Indiana is very consistent from the first of May until the first of October. If the ones you knew of went back to alcohol at $4.50 a gal and burn 67% more must have more money than sense. It is good for me that's all I care about don't care if anyone else uses it or not.
Have a nice day Stock car last time I respond to your stupidity on here. I don't give a xxxk what you run, your numbers are way off or maybe you run a little motor on a little track greased slick with no throttle and are on a 2 barrel. So stupid just as every one else says.
4time,
I emptied my mailbox out. Leave me your number. I use 6 or 7 gals of gas in a feature. I usually use 12 in a night. On alcohol I went thru 25 or more. An open motor would use more than a crate. I believe that the BSFC is or has a lot to do with how HP is figured. More fuel and air make a bigger explosion, which makes more power. That is why more airflow on one head will make more power than another.
Last season we started with a drum of race e85 at 310 a barrel once we used it we went with pump e85.It checked dead on the money all season long it averaged around 2$ a gallon all summer long.We can buy 10 gallons for 20$. 110 at the track is right at 10$ a gallon.We use it it a claimer type lift rule motor with a 600 vaccum secoandry Holley.The motor was good on gas but e 85 really woke it up.I have not drove it on track but have drove it on the road in front of my dads house it is much smoother and gives you the feeling he is talking about when you mash on it.We start with race e 85 because they claim the winter mix will be like e 70 I have not checked it myself but will this year.We will never go back. One more note Brad Hibbard said they saw no HP difference between renagade e85 which we used and pump e85Last edited by RW57; 02-15-2016, 03:04 PM.
Race fuel prices are more dependent on chemical prices than gasoline prices. But in Florida, Renegade has actually lowered their race fuel prices, and they were already the lowest priced race fuel.Mike Croley
Palmdale Oil Company/Renegade Racing Fuels of Florida
386-341-4308
