How about some info on MSD's on low voltage???
  • dynoman14
    • Apr 2008
    Maybe EP PAT, or someone else who has tested can help out...
    Can you clear something up?
    Many folks think MSD boxes run fine on low voltage ( below 12 ). My repeted tests with distributor machine and oscilliscope and amp meter tell me different, along with thousands of runs on the chassis dyno.
    What are your thoughts???
  • odb93
    • Jun 2009
    • 27
    If you trust Circle Track....
    Here's article on that very subject.
    • ep33510
      • 927
      dynoman14
      The short answer, if you want to just run the MSD box and have just AVG. output from the MSD box then 12 vdc and under is the way to go. But!!!!! if you want to get everything out of the MSD box then More is better. But that being said you want the box to think it is sitting on a bench a foot away from the battery source. You want to make sure that the voltage & current are solid and Never drift around to. The boxes are more efficent and effective the higher the voltage supply. If anyone is interested I have some options for you to look at for your racing program. You had it right Dynoman14 it does make difference as you have found out with the testing you have done. A Happy MSD Box is one that has a Solid Power source!!!!
      Ep33510
      Pat Collins
      techwest@techwestracing.com
      Pat Collins
      TechWest Racing Services
      MSD®Ignition Upgrade / Repair/ Technical Support
      8904 Sutherland Dr
      Huntersville,NC. 28078
      704-995-4286
      www.techwestracing.com
