604 Leak Down
  • talclipse
    • 738
    604 Leak Down
    What do most of you consider to be the service limit when doing a leak down on a crate?
    I bought a used motor and I'm not sure how much life it has in it before it will need freshened. Thanks for any help.
  • brad hibbard
    • Oct 2007
    • 974
    everybody likes to see it 6% or less but that is rare in a used crate engine
    1 thing that will make a difference is---when did this engine run last?
    if possible---start the engine and let it get to operating temperature and then let it cool down until the next day
    this will clear any build up that might give you a bad leak test
    we always remove the rocker arms headers and carb
    all cylinders leak something and knowing where the leak is, can help you determine the power loss
    we have had engines in the low to mid 20's that make nearly the power of an engine under 10%
    we recently had an engine with high 20's and the customer could not wait for a rebuild--
    I told him we would dyno it and MAYBE it really isn't all that bad---
    But the dyno confirmed that high 20's is too much---it was down 30 peak HP and was really ugly on torque through the middle rpm range
    hope that helps -
    Brad
    • talclipse
      • 738
      Thanks Brad.
