604 Electrical Problem.. Need help!
  • wildman31
    • Nov 2013
    • 25
    Have a fresh 604 (I had it freshened). It runs very well at idle and timed just fine at 4000RPM. The problem is when I took it out for its first hot laps, it popped and cracked like crazy while in the throttle, like a backfiring noise. What do I need to troubleshoot???
  • cuda9009
    • Sep 2010
    • 29
    Try a new ignition switch
    • brad hibbard
      • Oct 2007
      • 974
      make sure you are rotor phased properly
      your magnetic pick up wires may be reversed
      if your distributor is locked (and it should be) this is very easy to check
      with the engine shut off align the timing marks (not zero) but what ever your timing is set at
      example: 34 degree mark on balancer with pointer on the timing cover
      now remove the distributor cap
      the rotor should be pointing directly at #1 or #6 (depending on stroke)
      if it is in between terminals then your mag pick up wires are reversed
      switch them and reset the timing
      problem will be solved
      if you have an old distributor cap ----you can drill a hole in it below the #1 terminal and actually check it with a timing light
      Brad
      • wildman31
        • Nov 2013
        • 25
        One of the 3 magnetic pick up wires had broken loose. Thank you Brad, took me right to the problem.
        • CCHIEF
          • Jul 2014
          • 399
          Interesting, 3 wire pickup coil...???
          • wildman31
            • Nov 2013
            • 25
            Yes, it had black, red, and green going to a connector.
            • brad hibbard
              • Oct 2007
              • 974
              Oh Man,---that sounds like a ready to run distributor that does not use a box
              simply hooks to a coil and that is it----is that what you have?
              I have never heard anything good about those but out of curiosity I had to try one because of the simplicity---
              it never left the dyno----the thing had all kinds of issues and everything was new
              I switched the engine to a 6AL box and standard MSD distributor and it was instantly fixed
              Brad
              • wildman31
                • Nov 2013
                • 25
                It's an HEI Distributor. Part number 8365. I am running a 6AL box. Would it be best to go ahead and change to standard?
                • CCHIEF
                  • Jul 2014
                  • 399
                  With or without ignition module?
