602 pushrods?
  • lancer6187
    • Apr 2011
    • 2
    602 pushrods?
    New to the crate racing. Just Purchased a car minus pushrods, carb, and distributor. Need some help with the pushrods. Only information i can find on them are gmpp#14095256 cant find the length or wall thickness. Would apreciate any info!!
  • Egoracing
    • 4852
    Length and wall thickness do not matter as the GM part is the only part allowed. They are about $16 each or $256 a set from what I can find. The real question would be why were the original ones removed!
    • Egoracing
      • 4852
      Scoggin D i c k ey has them for $12.78 each. (Had to space it out or it would not post it.)
      • lancer6187
        • Apr 2011
        • 2
        The GM part# actually crosses over to a Sealed Power part # for about half the cost. I bought the engine used and some of the rocker studs were pulling out of the head messing up the end of a couple of the pushrods. The valve springs seemed way to stiff, i think that was causing the rocker studs to pull out so i put a new set of gm springs in and havent pulled a stud out since
        • Egoracing
          • 4852
          A lot of parts mfgs. have cross over parts that look close to the same and will work the same but are not legal. If you are running a crate class like Fastrak or Nesmith, they check push rods for length and diameter and I have seen them check the hole size. If any of your parts are off you will be banned for a year and loose the parts for cheating.
