Brinn Slip Yoke Question
  • racecartom
    • Apr 2008
    • 19
    How long of a slip yoke are u guys running on your Brinn transmissions?
    Thanks.
  • Mad Jack
    • 25
    RCT, It depends on how old your transmission is..? 70001 Trans Serial # 3858 or higher you could use a 8" if you want If the number is lower you will have to get a different 74010 Output Shaft to update it. 70010 Mag. Trans # 191 or higher same as above info. Unless the lower number trans has already been updated. The serial numbers are Hand Stamped on the top of main case and the same number will be in the top of the flange of tail housing.
