Radius tooth pulleys
  • brett4
    • Sep 2010
    • 88
    Has anyone seen any dyno tests on v-belt type pulleys vs radius tooth pulleys????
  • brad hibbard
    • Oct 2007
    • 974
    brett,
    there are contributing factors to the draw of power from pulleys
    the big ones are ratio and slippage
    the HTD (radius tooth) has no possibility of slippage so in the FIRST part of discussion it will take more power to operate however since there is no chance of slippage you can run less pulley speed which will net more power to the driveshaft
    also the HTD stuff does not have much tension which also enhances the power a bit
    there are upsides and down sides to all the types of pulleys
    1 special note when using HTD pulleys
    you cannot run a heavy high pitch steel fan
    you must run a lightweight fan
    upon deceleration a heavy fan will rip the belt apart because it has no slippage
    good topic
    Brad
