E85 fuel system
  • Younggun32
    • Jan 2014
    • 28
    E85 fuel system
    What are the recommendations/requirements to run E85 in a 604? i know this has probably been brought up before but i couldnt find anything.
  • fastford
    • 4059
    carb set up for e85 and knowing for sure your fuel is right , different distributors will vary a little , some times might be e83 , sometimes might be e87 , we use a tester , which is a must , and adjust with with gas or ethanol to be sure were at e85 , I now buy from a distributor next door and they have been dead on for last 2 years , I think there all getting better at controlling it now though , with every thing right it will perform as well or better IMO than racing fuel for about 1/4 the cost......
    • brad hibbard
      • Oct 2007
      • 974
      fastford nailed the 2 biggest requirements for success with E85
      specific built carb---NOT a conversion kit or your buddy saying he can drill the jets out
      Ethanol content---fastford covered this very well but I just wanted to add this---
      if you are buying your fuel a commercial station---depending on what part of the country you are in ---this time of the year you might be getting "winter blend" and that is usually around 70%
      it is very difficult to bring the content up
      If your plan is to use E85 from the corner station ---take your test tube with you and test some before you buy a large quantity
      just my 2 cents
      Brad
      • fastford
        • 4059
        I guess because of the milder temps down here , e85 dont vary as much as up north , plus where i get mine seems to be a better distributor than some others , but like brad said , best to take tester with you and pull a little bit out and ck it first , if its way off , go some where else , thats kinda what i did to start with.....
        • Younggun32
          • Jan 2014
          • 28
          Im going to run renegade just trying to decide on a carb now. thanks for the help guys
          • stockcar5
            • 1289
            Ethanol should work well for you. It makes more hp and tq. Over race gas it saved me about $2000 last year in fuel costs.
            • CCHIEF
              • Jul 2014
              • 399
              And your engine will run cooler,I'd run a circulating system. Regulator with bypass/return line.....on any fueled crate car.
                • 2020
                Make sure your foam in cell is E-85 compatible or you will cuss later on. Obviously, you can remove it and use something else for baffles, but be aware normal foam will disintegrate in E-85.
                • huckleberry_hound
                  • 206
                  we just purchased a new ATL fuel cell and the sticker on it says the foam that's in it is compatible with gas and e85,,,the sticker also shows a different foam to use when running alcohol,( they put a mark beside the foam thats in the fuel cell) so I guessing e85 doesn't have enough alcohol in it to harm the foam thats in this cell? Has anyone ran these cells with this foam and e85 without problems? just don't wanna take any chances, had foam issues with straight alky in the past,,,
                  • stockcar5
                    • 1289
                    E85 isnt nearly as hard on fuel system components as methanol is.
                    • Punisher88
                      • Nov 2014
                      • 495
                      I run e112 from renegade and have been very happy with it. Instead of being mixed with 93 unleaded it's mixed with 112 leaded fuel. For the exact same cost. When they check e85 they only check the ethanol content or amount. Not the octane.
                      • stockcar5
                        • 1289
                        for the same cost as what?
                        • brad hibbard
                          • Oct 2007
                          • 974
                          back in the beginning of all this ----I purchased 99% ethanol from a fuel distributor and mixed in 110 leaded race gas to create 85% ethanol
                          it was absolutely the worst accelerating mixture that I had ever seen
                          with some research we found that ethanol alone is a slow burning fuel and difficult to get a good burn rate
                          when gas is introduced to it the gasoline acts as the igniter for the ethanol
                          high octane (race gas) also has a slow burn rate ----so we attributed our failure of a "special" blend to having 2 slow burning fuels in a low compression engine.
                          we have used this theory for nearly 13 years now and have had no reason to believe different.
                          think about this---
                          northern states go to a winter blend during cold months which is about 70%
                          this is because the flex fuel cars will not start on 85% in cold weather
                          here is another example---
                          just about every time I have a customer call and say they are sluggish on restarts we ask what the content is and they usually have a content around 90%
                          when we have them bring it down (with cheap pump gas) to 85% the response immediately comes back
                          our theory has been that the low octane gasoline is what gets the ethanol to accelerate----
                          we honestly only tested 1 time with high octane gas and formed an opinion ---maybe we should revisit the concept
                          Brad
                          • stockcar5
                            • 1289
                            When I switched from race fuel to E85 (pump blend) I noticed a big difference in throttle response. The E85 is night and day better.
                            • Punisher88
                              • Nov 2014
                              • 495
                              For the same cost as regular e85. E112 costs the same as e85. Still 85% ethanol but is mixed with leaded 112 race gas.
