How many guys are experiencing issues with the 525 GM engines out there? Seeing and hearing of oiling issues and pistons or wrist pins coming apart in my area and wondering how widespread the problems are. Thanks
CT-525 Issues
Guys running them from your area that I know of are Marshal Fegers and Don Shaw, I'm sure Marshall hasn't had any problems and don't think Don has either but can't say with 100% certainty on Don.Originally posted by TLCT1 View PostHow many guys are experiencing issues with the 525 GM engines out there? Seeing and hearing of oiling issues and pistons or wrist pins coming apart in my area and wondering how widespread the problems are. Thanks
we are NOT a CT525 shop but we enter into the discussion with GM representatives about the common failures
most failures are oil related and more specific new engine prime related
cranking the engine to get oil pressure is a sure recipe for failure
new engines need to be primed with a pressure tank or drill operated in-line pump like the Peterson drill operated pump http://www.petersonfluidsys.com/Imag...front_main.jpg
"IF" Race-1 ever gets into the CT525 market --every engine will have this product coming with it --NO questions asked
this external primer should be used on these engines for every start up
just my opinion
Brad
Use a Canton Accusump tank with a oil pressure switch and solenoid controlled valve. Canton has a complete kit.It prelubes the engine when the ignition is turned on with 2 quart of pressurized oil and also lubes engine if the oil pressure every drops below 25 psi. Once the engine oil pressure normalizes the tank is filled and ready to go again. Cost about 600 bucks but it will definitely save the engine.
