we can use any spacer we need a little more on bottom
do spacers make a difference
Spacers do make a difference in where the power is made. This was several years ago but in back to back tests on a 604 between a 1" and 2" hvh 4 hole spacer, the 2" made significantly more torque at a lower rpm than the 1" on Sunoco GT260. By memory it was 30 lbs/ft gain at 4500 rpm peak vs 4800 rpm peak. No notable gain or loss in hp. The fuel has a lot to do with what you will notice though.
