604 distributor gear
  • 50j
    • 1047
    I'm finding conflicting information about something. Will the factory installed distributor gear on a MSD Pro Billet 85551 work fine in a 604 or does it need to be changed?
  • brad hibbard
    • Oct 2007
    • 974
    YES---the black MSD gear that comes on a 85551 distributor works fabulous on a 604 or 602 camshaft
    On the 604 you can use bronze if you prefer but we never do
    you might have some conflicting information because of a few things---
    1) we have always known that an aftermarket roller camshaft required a bronze gear and to my knowledge that still remains true --however the factory 604 camshaft is produced with a material that is compatible with iron or bronze
    this is true for distributor gear and fuel pump push rod
    ****NOTE**** 602 camshafts are NOT compatible with bronze
    Race-1 602 Fuel Pump Pushrod and Distributor Gear Requirements Questions or Problems contact us at: Ph.: 330-540-7223 or email brad@race-1.com (all information belwo is a recommdation from Race-1 not necesarily from GM) The camshaft in the GM 602 eng
    2) there are look alike MSD distributors out there that use a much softer gear
    it tears up quickly and usually damages the camshaft
    Many people relate this look alike product to MSD and it's not
    Genuine MSD gear works great and is what we use and recommend.
    Brad
    • 50j
      • 1047
      Thanks Brad, that's exactly what I was looking for. MSD calls the factory gear "melonized iron" and most of what I found for hydraulic roller cams called for a melonized steel gear. Splitting hairs I'm sure but I wanted to check. Thank you!
