GM Aluminum Bell Housing
  • ace1
    • Oct 2007
    • 205
    Will a stock GM aluminum bell housing be ok for a crate car. I think it would be as good as the bert or brinn. Most of those have been cracked and repaired.
    Yep, we ran one in a limited car a few years ago.....no problems!
      I've used them up to 600 hp. If you have an adapter ring machined to adapt the GM truck bellhousing down, even stronger.
      • ace1
        • Oct 2007
        • 205
        I think that is the one I have. The hole is about 5 1/8". But I don't have an adapter.
          I wouldn't run it with no pilot like that.
          • ace1
            • Oct 2007
            • 205
            Oh no, I'm not. I found a crack in it around the starter cup any way. I'll keep my steel bell in for now. Thanks
            • JustAddDirt
              • 1893
              drill a hole at the end of the crack to stop it.
              then die grind down the center of the crack on both sides, and have a good aluminum welder weld it.
