Originally posted by north louisiana dirt
View Post
Fuel maybe over flowing and flooding carb due too:
1. Floats being to high
2. Too much fuel pressure thus over filling bowls and running into boosters of car or out the vents
3. Fuel pressure keeps climbing and at end of straight its too high and overflowing and once you lift on throttle for entry (no longer consuming the fuel) it over flows into carb and thus when you pick up throttle it's pig rich and takes a while to keep out
It may not being doing it as bad on the top of the track (assume banking on top and none to little on bottom) because the car is leaned less to the right due to banking. It's possible you need an angled spacer on carb so fuel isn't going to the right side messing with float levels and over filling enough that it's running fuel out of the vents or boosters.
Keep in mind that large needles and seats don't require a ton of pressure, think large hose and low pressure to deliver the same amount of fuel as small hose and high pressure.
