E85--Oxygenated Gas--Pump gas
  • Doc88D
    • Jun 2012
    • 170
    Would E85 benefit at all with a top end lube added?
    Doc
    Facebook.com@DowdyRacing
    • fastford
      • 4059
      might help a little with cylinder wear , but I dont think it would be worth the trouble ....
      • dynotimeonly
        • 988
        Brad,
        What have you discovered with E85 that is stored in a plastic 55 gal drum? I hear there's a pricy nitrogen deal that should be used to remove moisture? I switched to E85 this year because I only race 5/6 times a year. (Got sick of getting my ass kicked on re-starts).
        Also, this fuel smells like ass! what's the harm in adding a cap full of scented fuel juice to the cell? (Bubble gum, cotton candy ect). I hear that's considered an "additive" in tech?
        Thanks mister,,,,,,
        • 3Hracer
          • Feb 2021
          • 9
          Any more discussion on E85. Pros cons
          • rocket1*
            • 43
            What kind of fuel pressure do you run on E 85 ? The same as gas?
            • Jking24
              • Oct 2017
              • 1519
              Fuel pressure is more related to the needle and seat size than the fuel type. You should get that info from your carb builder
              • EvelB7
                • Jan 2018
                • 907
                E85 requires more fuel volume, not necessarily pressure (which means the restrictions in the fuel system have to be changed) - unless you are running a super bowl, then pressure is a big deal.
