Electric fan
    Electric fan
    Has any one used one successfully on a crate engine? If so, which one?
    I know Bloomer ran one successfully a couple years ago.
  • brad hibbard
    • Oct 2007
    • 974
    several years ago I was at a 100 lap superlate race in WV that bloomquist was in.
    at the half way point as he was lapping most of the field his car erupted in steam
    a couple laps later there was a caution for a soaked down area on the race track but bloomquist remained on track and in the lead----he completed the next 50 laps and won the race without another trace of smoke or steam
    we all thought it must have been someone elses car and just looked like his car until we went to his pit after the race with curiosity about his tire wear
    when we arrived at his pit area it wasn't tires that we were looking at but a water pump that had broken off the block and was wedged in the steering
    Scott was commenting on how hard it was to steer the car the last half of the race but anyone with the slightest bit of engine knowledge was in shock about running 50 laps without water or a water pump
    I learned later that high end coatings make it possible for this to happen----I would not have believed this story if I didn't witness it personally.-----simply amazing
    zero ---I have some comments about electric fans but I have to get to work right now ---I will add them later
    Brad
      • 14303
      I drove a poor man super that probably made 500 hp, several times with an electric fan. Never a cooling issue. So, it can be done. Especially if you ran e85. You'd need a decent alternator. It might not be worth anything except to disengage alt and fan for short periods of time.
      • Punisher88
        • Nov 2014
        • 495
        I've considered trying the new spal fans. I believe that's the correct name. They are brushless and very popular with drag racers that build em to be street cars also.
        • Henry Every
          • Apr 2023
          • 613
          I've read many posts by those with the same idea and everyone of them give it up after spending thousands on radiators and multiple fan setups. JMO, I think its an exspensive gamble that may or may not work and give marginal benefit. Now Bloomer disconnected his fan at a crate race to qualify a few years back and set fast time but was disqualified for it... I think there is more speed to be had from focusing on driving technique and refining the setup. JMO.
          "In the Republic of Mediocrity, Genius is Dangerous." - Robert Green Ingersoll
            Scott actually won a 10k crate race at Swainsboro with one, then he was dq'ed because it was a track rule and not a sanctioned CRUSA race!
            Hendren recommended to run one, said a standard fan took 25hp! Thats a pretty fair amount for a crate!
            • EvelB7
              • Jan 2018
              • 881
              Standard fan does not take 25hp...
                • 14303
                At what speed? I've seen Dyno test results of over 20 hp for fan vs no fan
                • EvelB7
                  • Jan 2018
                  • 881
                  Chassis Dyno, most I have seen was around 16hp. If I remember correctly it was a 19" 4 blade fan, but I could be wrong on that. We spent quite a bit of effort trying to get an electric fan to work (604 crate car at the time), finally gave up. Quite a while ago, maybe the electric stuff has improved enough to work. Never saw 25hp down when going from fan to fan to no fan..
                    • 2019
                    Did you have the STD crate serpentine pulleys? If so I'm gonna assume it was the std 10% reduction on speed or was it more?
                    • EvelB7
                      • Jan 2018
                      • 881
                      Yes on the pulleys. It has been along time, but I remember the 16hp and we quit chasing it after not being able to cool the car with the electric fans. I still do some occasional work on the dyno, maybe take a look at it again and put the results out (will not be soon, but maybe over the next few months).
                      • Henry Every
                        • Apr 2023
                        • 613
                        He ran third at the fan race(2018) behind Overton & Kyle Bronson.
                        Bloomquist Qualify DQ
                        Race results
