I just put a new set of beyea headers on my grt and i didnt notice how close to the ground the drivers side was till i took it off the jack stands. The muffler is about 3 1/2 in ches from the ground at ride height. That seems way to close. Is it supposed to be that close? I would think that on a rough track it would hit. There is no other way for it to go as far as mounting the extension and the muffler.
how close is too close
my beyas were just about level with the frame rail. Make sure when you slide the extention on you turn it correctly and come under the second door bar. Should be right in between the first and second door bar
our left header was the same way. wasnt a problem until we went to load in had to jack the front of the trailer up a couple of inches to get it to clear because i was so close to the ground. we just cut the turndown collector and turned it sideways so it gave a little more clearance.
