Im goin to a split valve shock on the lr behind axle with a 6/2 shock.. what shock valving would be most recommended to run on the front of axle mounted on the birdcage with the 6/2 shock? track stays sorda tacky to little dry with a little rubber,groove is on the top most of the time Thanx
shock on front of axle Grt???
shocks
You need to contact Jerry Link at Shy racing Suspensions he can put you were you need to be on shocks for a very reasonable price 6152256022 tell him albert sent youOriginally posted by hobbyracerbn2 View PostIm goin to a split valve shock on the lr behind axle with a 6/2 shock.. what shock valving would be most recommended to run on the front of axle mounted on the birdcage with the 6/2 shock? track stays sorda tacky to little dry with a little rubber,groove is on the top most of the time Thanx
