I am looking at getting into Late Model Racing next year and the series that I am looking at is a Pro Late Model Series. I can't find much information on it and was wondering what the difference between all the other series like Super, Pro and Limited??
Pro Late Model or Limited Late Model? What's the difference???
does the series have a website where the rules are posted?
most "limited" late models around my area are a 11-1 steel head spec type motor with pretty restrictive motor, shock, and tire rules. the "pro" to me makes it sound more like a super late model, which allows for more motor, shock, and tire options.
Depends on where ur from...in central illinois Pro LM is a crate series...they run a 604 or 602 GM crate motor...limited is a steel block w no dry sump allowed...super is pretty wide open as far as engine rules
a guy on a budget should definitely look into the Pro LM series. it is economical and pays better than limited....even if u had the budget for a Super if ur just starting out Pro LM is still the way to go imo
The series is Ken-Ten Pro Late Models. From what I've seen, it looks real similar to the Limited Series. My chassis is based on a '76 Chevelle frame and need to know that this is allowed.Originally posted by rubbinsracin View Postdoes the series have a website where the rules are posted?
So, am I right in saying that the Pro Series is the middle of the road series with crate motors. What about chassis type requirements? Are you familiar with Ken-Ten Pro Late Model Series?Originally posted by 6wRacn View PostDepends on where ur from...in central illinois Pro LM is a crate series...they run a 604 or 602 GM crate motor...limited is a steel block w no dry sump allowed...super is pretty wide open as far as engine rules
Ken-Ten Pro Late Model Series is asphalt, 4m is 99.9% dirt racing, you will not find any all out engines in asphalt racing and you can build an engine OR run a crate engine and you can run a fully fabricated car or a clip car.
Where and what tracks/series. The typical dirt super late model motor has more power and torque than a NASCAR engine, I have not seen a single series that runs 800-900+hp on asphalt, I am not saying that there may not be some but I have not seen them and would love to see the rules.Originally posted by ford396 View PostEgo, I am not sure where your idea of no all out engines in asphalt comes from. I can say that around here the super late models are all out, as well as many of the modifieds. ???
Dixie Outlaw Late model engines would be a very limited "limited late model" dirt engine.Last edited by Egoracing; 08-29-2011, 06:24 PM.
