Bed Your Engine
  • brad hibbard
    • Oct 2007
    • 974
    Bed Your Engine
    Race-1
    Recommendations On How To Put Your Engine To
    Bed For The Winter
    First and foremost---if you are not storing your engine/car in a garage that is heated 100% of the time you need to get all the water out or install antifreeze in the system NOW.
    We recommend putting at least a gallon of antifreeze in anyway.
    Next
    Disconnect the feed line to your fuel pump and run a hose from the pickup side of the pump into a fuel jug with quality gasoline (AV gas or 93 octane pump gas) it is also recommended to mix 2 stroke oil into this gas
    Placing the fuel jug into a safe location away from headers
    Then warm the engine up to operating temperature
    After the engine is warm begin drizzling straight 30 wt. motor oil down the carb at a high idle (1300 to 1500)
    Once the garage becomes filled with smoke increase the stream of oil and choke the engine out with oil.
    Next take several oil soaked rags and stuff them into the ends of the headers.
    If you want added security remove the rocker arms so all the valve springs will be relaxed
    If you used a mixture of two stroke gasoline for your fogging process and made sure the secondary side of the carb was also flowing fuel during fogging then there is no need to do any further carburetor bedding but some like to remove the carb drain and fill with wd40.
    When wakening up the engine remove the spark plugs and spin the engine over a time or two to release any excess oil then prime the oil system reinstall the same plugs to initially fire the engine
    You will need to change spark plugs after you warm it up and clear the winter oil away
    This process does not take long and will help to insure your engine will wake up the same way it went to bed
    Any questions please call or e mail through our web site
    Brad
    330-540-RACE
  • joedoozer
    • 745
    How long of an off season is considered long enough to do something like this? 2 months, 4 months, 6 months or more?
    Crew Chief "Tip of the day":
    • brad hibbard
      • Oct 2007
      • 974
      Joe
      If the engine is exposed to moisture or if you normally run oxygenated fuel
      as little as a week could result in damage to your engine
      of course there would be no need to go to the full extent that I described but some fogging should be a regular practice
      Brad
      • joedoozer
        • 745
        Our season is split in halves. We are off 2 months in the winter (Dec and Jan), and then 2 months in the summer (Jul and Aug). I do run 93 pump gas and I use Sta-Bil at every fill up. I had planned on draining the fuel system and carb after the last race. Would fogging be a good idea for a 2 month break in this case?
        • brad hibbard
          • Oct 2007
          • 974
          Pump gas alone has ethenol in it which will draw moisture
          the stabil that you add is intended to maintain the fuel quality---I don't know if there is any lubricant in that type of additive but if not I would do some sort of fogging
          to what extent would be a judgment call that you would need to make based on the humidity and temperature conditions in your storage area
          Brad
          • stock car driver
            • 3233
            Good info thanks.
            I usually error on the lazy side and dont do too much for off season.
            Ive usually got a motor or two that Ive ran and pulled as a spare that I should take better care of for storage.
            • joedoozer
              • 745
              Brad
              www.race-1.com
              It does not freeze in my garage but Dec. - Feb. It will being in the high 30's and low 40's at night. I may run a small mixture of anitfreeze to err on the side of caution. I did read in the paper today (well my Dad did and then picked on me because I don't read the paper), that a local fuel station is now carrying non-ethanol fuel. I am going to look into this. Adding Sta-Bil to the fuel is expensive, and raises the cost of what I am paying per gallon.
