front shock/spring ??
  • teamf5
    • Nov 2011
    • 3
    we have a right front shock with 4.5 inch of shaft at ride hight but we are beating the stopper up bad. we are at a 400 spring now and the car can get loose off a stiffer spring shoud help. but what is to much need to stop using up so much shock. or is there something else wrong other than a week spring. never had to use this much spring before. if any one has any ideas it would be appreciated.
  • joedoozer
    • 745
    Are you sure its not just one big hole that is pushing the rubber down all the way? A stiffer spring would help.
    Crew Chief "Tip of the day":
    • teamf5
      • Nov 2011
      • 3
      running a 4-8 afco the rubber indercator is being smashed into the bottom nut. are tracks do suck on the holes. was thinking of double stacking it to try and not have to get to stiff but never ran it before
