Crate shock ?
  • lemke7
    • 47
    Crate shock ?
    What shocks are most crate racers running? Also, what shock builder are most using? Thanks
  • supercomet32
    • Jan 2009
    • 186
    Id say more likely than not most are running either what the chassis manufacturers recommend or a cheap set of DA shocks like an afco DA or similar. saving the budget with the motor and the most adjustable option saves money.
    when i run crate i still use my integras or the last set of PRO's that i have but i wont be replacing them. Integras work and i just have them rebuilt as needed.
    • mqdirtracer57
      • 493
      I would personally pick a shock builder in your area. They would suit you more in getting you in the right direction on shock set-up. They would most likely know what type of racing conditions you race in and also be able help you adjust your set-up to track changes. If you are looking at a Double Adjustable type shock.The AFCO Silver Series are an economically priced alternative and on top of that,if you win using that shock"AFCO pays you $100.00 for each win".
      • RNU4PNKS
        • Jun 2010
        • 8
        Any advantage to cannister's
        Reason I ask is our local track is said to be allowing DA's for next season but non cannister????
