Water pump question?
  • bb1527
    • Mar 2010
    • 33
    Guys I just traded my steel head motor for a 604 crate. I was trying to bolt my water pump up (short style) and it appears that it is hitting on one of the timing cover bolts. I think it may work if I take the bolt out or take it out and grind the head down. My question is will that still be legal for Nesmith/ Fastrack series? Or will I have to buy all new pulleys and water pump?
    Thanks for any input!
  • 9WRACER
    • Feb 2009
    • 585
    my 604 has a spacer plate on each side where the pump bolts to the block, works great!
    • brad hibbard
      • Oct 2007
      • 974
      Grind it
      Take the bolt out and grind the head down to clear.
      you MUST remove the bolt to grind-----grinding on the engine will melt the cover or rubber seal
      sometimes you have to get it pretty thin but a 6 point socket will install it just fine
      spacer work as well but then you will need to space your crank pulley and that can cause problems.
      Brad
      • brad hibbard
        • Oct 2007
        • 974
        Also if you were using a cam stop on your steel engine make sure you remove it or back it off it will break the plastic timing cover
        Brad
        • bb1527
          • Mar 2010
          • 33
          Thanks for the help! I didnt want to go the route of spacing the pump due to the trouble of lining the pulley up afterwards. I ground it down and it worked fine!
