clutch and fly wheel
  • mus06
    • May 2010
    • 64
    what engine would i get and clutch fly wheel and pressure plate for it is a 602 engine just wondering what to tell the part store is it the same as a 350 or what all i have is a stock 3speed chevy trans thanks for any help
  • dirty white boy
    • 1238
    a 3 disc 7 1/4 set up be best,if with'in your rules,...you on dirt or asphalt???
    white trash motorsports
    • mus06
      • May 2010
      • 64
      we run on dirt
      • mqdirtracer57
        • 493
        Triple disc would be the way to go....If you are looking to run a stock type set-up.I would think a flywheel from a mid 90s Camaro with stock clutch and pressure plate,using an aftermarket hydraulic throw out bearing. Just remember to use an externally balanced flywheel for one piece rear seal...
