602 carb question
  • DIRTFUNFAN
    • Feb 2009
    • 62
    602 carb question
    i am buying a used 602 to run in a street stock class have a few questions... First off i have to run a holley 4412 2 barrell that passes a track tool.. i have a 4412 that we have ran for years that i need to have rebuilt.. any reconmendations on who to do it? i dont wanna buy a $700 carb to run for $200 to win... also the motor i am buying used has no distributor, water pump, or fuel pump... where should i buy these parts? whats better than the other.. thanks for any help u can give me!!
  • dynoman14
    • Apr 2008
    4412 Rebuild
    If you don't want to spend the extra money buy a rebuild kit and install it. It takes about 30 minutes and if you do everything right it will run just like it did before you took it apart.
    If you are running pump gas you might want to invest in viton or alcohol needle and seats, alcohol resistant power valve and the new style synthetic green or gray gaskets. Left turn float also helps.
    You can get the parts from BLP, Braswell or any of the specialty carb folks. If you have problems I can build you a kit with the good needle and seat ( $22), left turn float ( $24), Alcohol resistant PV ($12) and accelerator pump ($9), Synthetic metering block and bowl gaskets and all the other stuff you need for $99 and $6 shipping. I include new screws for the bowl and accelerator pump, needle and seat assembly & throttle body to base plate. I purchase my bulk parts from BLP and Braswell.
    That 10-15% Ethanol is a real pain on small carb part and small holes in the metering blocks.
