How would a kse power stearing & fuel pump driven off back of engine on a 604 work.
How would a kse power stearing pump & fuel pump driven off the back of engine work. I ben told they only work on high hp engines.! Any help would be great.
You'd run them off the bellhousing mounting boss. You would need to have a htd drive on your coupler. I don't know about power loss compared to a normal fuel pump and power steering off of a serpentine belt
Have run this setup using E85 for fuel the last two years with no problems.Did not use the pills that came with it , capped return off and used a regulator and ran return line from it.
