Set up sheets
  • 06 Fan
    • Mar 2012
    • 1
    Set up sheets
    Can anybody help out with a blank set up sheet to use at the track to keep up with the base set up and adjustments made during the race.
  • Nutcase21
    • 16
    Setup sheets
    Longacre makes them GOOD get from most online parts stores
    • joedoozer
      • 745
      Check this thread. The latest version of his software has a print function. You can print out blank copies to have in a set up book.
      http://www.4m.net/showthread.php?212...cking-Software
      I like the software. It works pretty good and you can't beat the price .
      Crew Chief "Tip of the day":
      • merc123
        • 1261
        Here's a couple you can print for free:
        Web: http://www.t17.co
        • joedoozer
          • 745
          I used those when I first started. The problem I had with those sheets is they aren't detailed enough. Bar locations, 5th coil, 6th coil, shock details and so on.
          • BigBlueFord
            • 189
            Here's an Excel spreadsheet that I made up for our mod. You can prolly make a couple of minor changes for late model.
            Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
            • joedoozer
              • 745
              Here is a reworked one for a Late Model.
