DYNO:
"The next biggest gain is geting your distributor built to the right timing curve to match the engines acceleration after you get the carb right. If you are firing too soon you bind up the engine if you fire too late you run too rich. Getting it right is as much as 10-15RWHP."
I run a Super Stock, 625 HP, iron head 4 bbl ; 4900 to 7600 on our average tracks. Are you saying it would be beneficial to run a timing curve ( not fixed) at that RPM range?? I run a tach recorder and am surprised at how long the rpms are in the lower part of that range.
Thanks, Dave
Thanks, Dave
