figuring the right gear
  • steelkiwi75
    • 366
    only turning 6150 rpm with a 5:34. want to get to 6600. what gear should i run? how do you figure the gear? ie: if i went from 5:34 to a 5:44, what rpm change can i expect? thanks in advance.
  • Racer111
    • 796
    Alot of times 10 points of gear is 100rpm..
    • modified9
      • Jan 2010
      • 13
      gear ratio
      dividerpm you want to turn by current rpm multiply that number by current gear 573 what you need
        Modified9 nailed it.
        • lindsey97
          • Mar 2011
          • 84
          Dirt Forum Toolbox has alot of these calculators, just plug in your numbers.
