change to a crate
  • aknorr
    • Jun 2012
    • 19
    change to a crate
    Okay so my car has an open 358 in it with a bert. Now to change over to a 602 I will need, different headers, different pulleys, (carb should be okay HP750), and is there a special flywheel or adapter or something?
  • Egoracing
    • 4852
    Depending on the header they may already work. You will want 1:1 pulleys and a coupler or flywheel if running a revers mount starter with the 3 inch bolt circle. The 750 is going to KILL your lower end with the 602 and may be to big up top. Your best bet is a 650.
    • aknorr
      • Jun 2012
      • 19
      okay thx, I'm just throwin it together temporary as a budget set up to get on the track. Found a 602 with 2,000 laps on it in car still running for under $1000 so just wanna get out there cheap when that blows I will step up the equipment
