fan ?
  • OWM50
    • Mar 2009
    • 42
    fan ?
    did a search on this to no avail, what is the lowest drag fan to run on a 602.. looking to save maybe a little power
  • dirty white boy
    • 1238
    cv products!
    white trash motorsports
    • falaohao
      • Sep 2012
      • 1
      Very easily Stop smoking Smoking -- 3 Don'ts
      You want to very easily stop smoking smoking. That's exactly what you want to perform. Is not this?
      The simple truth is that we now have particular stuff that we should not really perform Electronic Cigarettes in the event that you want to think it is less complicated in order to give up cigarette smoking totally. It is crucial that people observe this stuff. After we have them taken care of, the thoughts is going to be obvious in regards to what fails.
      Avoid using any kind of type of medicine
      It's very astonishing which many people came using the indisputable fact that some type of deep breathing such as hypnotherapy might help all of us stop using smoking. This particular concept is extremely incorrect. Deep breathing will not assist all of us to stop. A large number of individuals possess stated it proved helpful on their behalf however it continues to be not really your best option to make use of.
      In the event that all of us think about the portion associated with smokers who've were able to be successful utilizing deep breathing methods all of us will discover that it's not really worthwhile. Investigation implies that no more than 10% of individuals that make use of deep breathing (especially hypnotherapy) wind up lastly giving up. While, Blu Electronic cigarettes we now have methods exactly where regarding 96% of these that utilize it wind up cigarette smoking and not return to this once again.
      Overlook the concept of e-cigarettes
      Many people are actually eager to stop. Within their paralyzing desparation, they're going forward to make use of the thought of e-cigarettes. Think me personally, by using this concept is certainly going within the panel, large period. The entire concept is actually getting some type of extravagant digital smoke at your fingertips to ensure that even though all of us place all of them within the mouth area in order to smoke cigarettes, all of us defintely won't be consuming smoking to the entire body. Really the actual smoke doesn't include something inside it. It's simply something which is actually extravagant. This particular doesn't truly resolve the primary issue. Will it?
      Smoking alternative treatment will not function
      Just about everyone has become frustrated through the type of outcomes that people obtain through using smoking alternative treatment items. Numerous possess created this particular treatment in an effort to very easily stop smoking smoking. However it's not. Exactly what we have to recognize is actually that people aren't hooked on cigarette smoking simply because all of us desire smoking. All of us desire the actual smoking and never the actual smoking. That's easy the key reason why this particular treatment joye 510 is actually of a bad achievement price.
      • SRXSRULE
        • Jan 2011
        • 217
        Ive dyno tested about 5 different fans over the last two years on my 602. What I found was lighter, thinner, less blades...HURTS hp and tq. The light weight nylon flex fan that weighs like 8oz was one of the worst performance. The flex-a-lite HP series that they claim is there best fan for gaining HP, also wasnt true. The fan I found that works best on my set-up is a steel, 6 blade 17" fan.
        I also found that the radiator, shroud and fan clearance/spacing all come into play with gaining or loosing HP. Air resistance and turbulance are key parts to this formula. Eric
        • jimmyanderson45
          • Sep 2012
          • 1
          I am lucky to have this place
          hahahahhaa
          Leathernote http://www.leathernote.com
          red leather jacket http://www.leathernote.com/leather/r...er-jacket.html
          motorcycle jackets for men http://www.leathernote.com/leather/m...s-for-men.html
          cheap leather jackets http://www.leathernote.com/leather/c...r-jackets.html
          motorcycle jackets for women http://www.leathernote.com/leather/m...for-women.html
          leather coats for women http://www.leathernote.com/leather/l...for-women.html
          • dynoman14
            • Apr 2008
            SRX,
            Wow, a man that did some testing and posted his results...I am proud for you and can confirm your results...You are also 100% correct on fan location and shrouding.
            The efficiency of the radiator is directly proportional to the pressure differential across the fins from front to back. Meaning the airbox on the front of the rad is as important as the shroud on the back creating a pressure diff. Without that all you are doing is moving stagnant hot air accross the fins. There is 60-100* temp reduction with using a proper air box and shroud. In most cases you can eliminate the manual fan and go to an all electric option. It does require a couple other areas to be addressed but can be done on almost any race car dirt or pavement.
            Did you ever take the fan off completely and see how much even the best fan drags the engine output down???
            GM's good steel fan pulls almost 38HP at 7000rpms.
            Water pumps are the same way they are very parasitic. You can easily make one pull on the chassis dyno without the WP belt on just to see...man do they suck power...
            • stockcar5
              • 1289
              on the dyno we lost 4hp and 2lbs/ft going from an electric pump to a stage 3 stewart. very little loss.
              • SRXSRULE
                • Jan 2011
                • 217
                Yes I tested no fan on the engine, It was no where near the power loss I had found others claim. I would have to double check my notes but it was either 7 or 11 hp to run my best fan set-up. I also run a stewart stage 3 pump.
                When you have to race a sealed motor, there is many ways to find extra HP
                Eric
                • shockermotorsports25j
                  • Mar 2010
                  • 58
                  Is it possible to run an electric fan. i.e flexalite setup etc. Ive always wondered. They have fans that can move the cfm and i imagine its free up some power
                  • dynoman14
                    • Apr 2008
                    Results will differ from test to test but I can tell you that running any kind of fan at 7000rpms will take way more than you think. Howard Stewart built a water pump dyno that I used to run plenty of stuff on and it was a large electric motor hooked to a fan belt and the amp draw was used to back calculate the HP it took to run whatever was at the other end of the belt. Pretty simple.
                    I can tell you we started with a 25HP electric motor and it was not enough, so we went to a 50HP and that made more things measurable.
                    I guess that is why Cup teams have spent millions of research dollars on how to run their engines in qualifying without running the water pump. or only running it part of the time. That is why the engines are spewing water after the first lap. If you have a 6 gallon water system and spew it out you have lost 40+ LBS in qualifying.
                    Nowadays they have to be able to do it without killing the engine or they have to start in the back which does not make much that much difference at Super Speedways and a couple guys have won from the back at some of the other tracks.
                    Most folks have been unsuccessful on dirt with electric fans because they don't understand that it takes electricity to run them. Batteries are in a constant state of discharge and can result in pretty big HP losses after as little as 25 laps. An alternator is a pre-requisite to getting the system going as well as a pressurized nose box.
                    What you are balancing out is the net gain in the amount of HP it takes to run an Alternator-vs- running a steel fan. Usually results are in the +15-25HP. All you have to do is look at every pavement car you see out there...if bladed fans were the way to go they would all have them.
                    There are a couple pretty fast crate cars out there running electric fans if you get a chance to see under their hoods.
                    • bluemod
                      • 214
                      Is an electric water pump the way to go. I guess you also have to use an electric fan also. So would a 16v battery work or would you have to have an alt.
