carb help
  • biggdawg36
    • 13
    carb help
    i have a quick fuels 650 carb it will not stop leaking fuel out of the right front booster when it is running have checked float level, power valve , but still leaks any other suggestions thanks
    Pull the needle and seat and blow it out with air. Even a very small spec of dirt or something can hold it open and let fuel through.
    • sidebite7
      • Feb 2013
      • 32
      I had the same issue with the same carb. problem was it had the wrong metering block gaskets. the incorrect gasket had a small hole that wasn't suppose to be there (3 circuit carb ). would seap over night and empty the bowl . needle an seat can also do it if there is something in it
      • biggdawg36
        • 13
        ok i have changed the needle and seat i thought it may be that as well ill check the gaskets to see if it all lines up thanks
        • sidebite7
          • Feb 2013
          • 32
          if its a 650 . the metering block gaskets should have a circle cutout for the power valve. not the Dshape cutout .
