im wanting to run an alternator on my 602 crate. The bracket i have mounts the alternator above the water pump. the problem is it wont fit under the hood in this spot. Does anyone knoe of a bracket that will mount it lower and on the right side of theengine? the power steering is on the left side.
602 crate alternator
Check Speedway motors, they had a hot rod kit that would would allow you to run any of 3 different locations.Originally posted by Dirt racer 10 View Postim wanting to run an alternator on my 602 crate. The bracket i have mounts the alternator above the water pump. the problem is it wont fit under the hood in this spot. Does anyone knoe of a bracket that will mount it lower and on the right side of theengine? the power steering is on the left side.
My next question is does anyone know of a production vehicle that would have a small alternator similar to the $400 dollar one speedway sells that would work?
I have a small LiTech racing alternator with pulley and bracket for sale. It mounts it to the right side head and drives with a small pulley that mounts between your fan and water pump. It uses a small 3/8" wide serpentine style belt. I ran it on my 602 before I converted to a 16volt battery. I'll take $165 shipped to your door if you're interested. E mail me at davemagee96@yahoo.com for pics
You can get differnt brackets here. http://www.powermastermotorsports.co...rack_kits.htmlOriginally posted by Dirt racer 10 View Postim wanting to run an alternator on my 602 crate. The bracket i have mounts the alternator above the water pump. the problem is it wont fit under the hood in this spot. Does anyone knoe of a bracket that will mount it lower and on the right side of theengine? the power steering is on the left side.2007 IMCA SUPERNATIONALS CHAMPION
