oil cooler adapter for the block
  • WENDEL ROCKET
    • Apr 2008
    • 277
    im wanting to hook up my oil cooler on my gm 604. i need the adapter that replaces where the oil filter use to be that has #12 fittings. what kind should i get?? i have a remote oil fillter base and a cooler on the car all ready i just need a block off adapter to install on the motor then plum in tho the cooler and filter.
  • perfconn
    • 3612
    CV781 and 2 fittings are seperate
    • WENDEL ROCKET
      • Apr 2008
      • 277
      i was reading about them online line and it says that the cv780 is for wetsump using a remote oil filter, the cv781 says it only has an inlet and no an outlet is that right? and also they only had a #10 holes i need # 12 for my oil cooler?
      • WENDEL ROCKET
        • Apr 2008
        • 277
        604 water lines on intake
        do you think that you need to plum the 2 water lines on the intake from front to back? mine just has plugs in it now. im just wondering if it would help with cooling ?
        • MM90
          • Oct 2010
          • 422
          For oil coolers #12 is designed for dry sump, #10 for wet sump. Probably gonna have to get the dry sump adapter.
