Can anyone tell me where the seal bolts are at on a 604. I am looking at buying a used 604. The guy says that is has GM seals on it. The only 604 I have been around had Hendren racing engines cable seals so the sealing is a little different.
604 Seal bolts
CircleTrackSupply.com is your one-stop shop for Race Car Parts, Tools, and Accessories. We are a proudly American family business located in North Carolina. Get the most out of your racecar with the best parts and friendly service at CircleTrackSupply.com We deliver Speed.
This is where you can buy some knock offs, but it tells you the location of them in the description.
2nd head bolt from the front on both sides------top 2 timing cover bolts------front 2 oil pan bolts and depending on the year of the engine intake seal bolts will be LF and RR for all 1P04 and 2P04 engines most 0P04 engines will also be in that position--------not posative about 9's but 8's and back will be RF and LR corners
the date code is on the RF corner of the block and is on all blocks
look for the encrpted code and the GM logo-------rusted bolts are questionable
hope that helps
Brad
PS ----that deal above clearly states NO lazer code ----also they rust very quickly
