crankshaft coupler
  • ncracer1st
    • 121
    crankshaft coupler
    Can you use a bert coupler with a brinn transmission?
  • sj valley dave
    • 1016
    We run a Bert coupler with a Bert bellhousing and a Brinn tranny...
    • ncracer1st
      • 121
      OK i figured it out. I have a Winters bellhousing, Brinn tranny with a Bert coupler.
      • 9WRACER
        • Feb 2009
        • 585
        Transmission doesn't matter Just be sure if you have a brinn bellhousing use a brinn flywheel, or a bert bellhousing use a bert flywheel. Bert flywheel is a little smaller, will work in a brinn bellhousing for a while, but after so long it will knock the teeth off as the starter isn't getting into the flywheel deep enough. Learned this the hard way!
        • cedarcreek
          • 15
          I run a bert bell housing and a brinn trans,bert coupler,no problems ever.
          • keeks
            • Oct 2008
            • 687
            I ran into this exact problem earlier this season. Keep the coupler matched with the bellhousing.
            If you do some measuring, you will see the subtle differences that will not allow one bellhousing to work with another coupler.
