Without running AN type lines, and trying to stay away from swivel outlets. What are you guys using?
Water Outlet for double pass
Thanks guys! hpmaster which swivel do you use? If you use the moroso piece, why not keep the rad. cap?
Because I've had problems with the upper housing leaking and the cap not sealing well. If your radiator is higher than your water outlet there is no need for the other cap. Buy a block off plate, silicon it up, you're done.
the allstar swivel neck does seem a little cheesy on the quality side but there is a ton of them out there and I have never heard of a single failure or leak
brad
Heck it is a nice looking chrome looking piece with double o rings and never has leaked. As for the make I have absolutly no idea who made it. Does look like a Trans Dapt brand 6016 but like I said I bought it years ago when I went with a double pass radiator. My radiator cap is on the radiator and the neck looks like a plain ol neck.
