power steering/ fuel pump mounting location
  • sidebite7
    • Feb 2013
    • 32
    does a reverse mount system that runs off the crank better than the standard setup that mounts in front of the engine? any reduction in resistance to the rotating assembly? I see the tandem system allows power steering and fuel pump to be ran in one unit . is there any advantage to this ?
  • brad hibbard
    • Oct 2007
    • 974
    KRC has actually tested this and found no measurable difference in a crate engine application
    what we hear from customers is that some prefer the rear mount pumps for better weight distribution chassis wise and also cleans up the engine compartment for maintenance and engine swaps
    Brad
