Motor Oil
  • hsracer
    • Feb 2011
    • 33
    Motor Oil
    This question might have been on hear before but. What engine oil are people using in there 602 and 604 crates and whats the best oil filter.
  • ptodd
    • 547
    we use brad penn with wix filters
    • joedoozer
      • 745
      Yeah Wix racing filter for sure. Part # 51060R, you can get it Napa and O'reilly's. I don't have a crate engine and I wanted to use Brad Penn 20W-50, but I had way too much oil pressure with it. So I had to drop down to 10W-30, I went with Valvoline VR-1. And I use an oil additive to bring the zinc and phos levels up to safely run it with a solid cam. If you are in south GA I would gladly sell you 6 quarts of the Brad Penn cheap haha. I will never use it.
      Crew Chief "Tip of the day":
      • ptodd
        • 547
        crate engine with brad penn oil pressure is in the mid 40's
        • Chris Steele
          • 1123
          We use Joe Gibbs Racing Oil and K&N oil filters.
          www.joegibbsracingoil.com
