Bought a grt with 604 a month or so ago supposedly only 7 races on engine. Good oil pressure, no visable leaks when I bought it. Cranked it the first time this weekend (been trying to get tools, safety gear together), and now I have an oil leak behind the harmonic balancer. What are my options? If I pull the engine and take it to a certified engine builder will they fix leak or only do a full a rebuild? These are questions I should've asked before buying but was so anxious to get going . Also, the oil inspection bolt is on the drivers side in front of the oil line on the flat top of the oil pan correct? And it has to be checked with the engine running? Any tips for doing this without burning my arm off on the headers?
604 Oil leak.
chances are your oil leak is in one of the lower corners of the the timing cover----where the timing cover, oil pan and block all come together
clean it off real good with brake clean and then hot soapy water----once it is completely dry pack a quality brand silicone sealer into the area ---try to actually push it into the intersection ----let it dry 24 hours and it should be fine
as for checking oil level----loosen the level inspection plug before starting the engine so that it is easy to remove when the headers are hot
Note:
if your oil level is too high it will lessen your chance for a successful leak repair---not to mention rob power and overheat the oil-----too high is just as bad as too low
Brad
Thanks Brad. I sure hope that works. I am looking at the correct bolt aren't i? Also I another stupid question: I'm guessing that would be the where to put oil in the engine? Are there any technical books or other sources out there on these crate engines? I've found tons on chassis adjustments but Other than this site, I have not found a lot of info as far as engine service and maintenance. Thanks again for your quick response. I'd probably be putting a big for sale sign on the car if it wasn't for you guys on here
Brad i am going to kind of highjack this thread... I am installing an oil cooler on a USMTS type motor with a sandwich adapter(will use CV to keep bill happy RIP buddy). I read your webstite and it states anytime using a cooler you should check it running. My question is how do i check the oil running, i dont have a plug in the side like these crates do. I just changed the oil every two weeks and pulled the plug on the right kickout to make sure it was close to the top.
powerslide-----CV does not make a sandwich adapter (that i know of) and i know exactly what you mean about Bill's diligence on this subject-----when using a Canton sandwich adapter we do some port work on it as an upgrade
the plug you are refering to "should" be a oil level inspection plug and that is where you will check the level with it running
Krooser
then engine has to be running in order to completely pressurize the lines and cooler-----without it running the level will show over full but by how much --no one can know
A ron
for more information you can check our website www.race-1.com under the "Race-1 Answers you questions"---its a tab just below the champions cup on the left hand side
also check out www.crateinsider.com
Brad
Thanks Brad, Yeah when i counted the oil and put them in it was usually right at the top of that plug. I will go with that running then. I was having a hard time finding a CV version but i think i found CV780 in a catalog that "looks" like a sandwich deal. If not i will get the canton one.
Thanks
CV780 is just a block adapter and then you have to use a remote filter
if you use Canton the # is 22-541 oil goes to filter and then to cooler---this is the recommended oil flow by GM and others
#22-540 goes to cooler and then the filter (not recommended)
BradLast edited by brad hibbard; 06-10-2014, 02:19 PM.
wrong answer powerslide (but i do see you ended in a question mark)
it has been found that there can be a pressure drop if the oil map is cooler>>filter>>engine
and that best oil flow is achieved filter>>cooler>>engine
as for powerslides reasoning----I totally disagree with that thought
ANYTIME there is an engine failure REPLACE the cooler and dillegently clean and inspect the lines
coolers are $250 how much is an engine?
in many cases its recommended to replace the lines as well-----debris becomes in-bedded in lines and coolers and then releases when it feels like it
YOU CANNOT WASH AN OIL COOLER ----PERIOD...
Brad
Thanks for sharing Brad. I didnt think that was the only reason but took a wild guess.
What brand cooler are you suggesting?
Most stuff i read suggest setrab. I emailed them and they suggested two different ones $454 and $383. I found the exact same part# new on ebay for almost $100 less.
we have been using a deck mount cooler marketed by Allstar performance (not sure who makes it)
it has 2 built in -12 fittings and a 1/2 pipe bung for temperature----its a quality piece at an affordable price
we searched for this type of combination to ease the pain of cooler replacement----it retails at $250 part #30145
we are always open for suggestions from the racing population for more options
