Slayer Cut tires is now based out of Lima, Ohio. You will see us at Limaland, Waynesfield, Eldora, Montpilier and other tracks around the area!!!!!
Our goal is to help keep the racer in mind and get the tire program in the right direction with good tire technology by making your tires have more speed with out using Tire Chemicals and to keep you from having to grind your own tires!!!!
We have proven many times now that we can not only save you money but get the best performance out of your tires each week, and get longer life out of your tires. We have proven it. We are currently doing U.M.P. Dirt Late Model Tires, U.M.P. Modified Tires, Bud Thunderstocks, and any other classes you would like done. We have drivers like Jerry Bowersock, Scott Bowersock, Brandon Vaughn, Jeff Koz, Emily Gade, Tony Anderson and many more!!
U.M.P. Late Model Pricing:
Mount / Dismount: $20 per set or $5 a tire/wheel
Grooving, Needling, Siping (If Needed), and Surface with our Surfacing Methods:
$120.00 a set (or $30) a tire
Resurface and Needle: $100.00 a set (or $25) a tire
U.M.P. Modified / Bud Thunderstocks / any other 8" Tire
Resurface and Needle: $75.00 a set (or $20) a tire
***Used Tires For Sale From Time To Time***
***If you want to miss match and just get 4 different tires done, prices remain the same****
GIVE US A CALL/TEXT OR COME TO JERRY BOWERSOCK'S PIT ONE NIGHT AT ONE OF THE LOCAL TRACKS AND ASK FOR CAMERON!!!
SLAYER CUT TIRES 270-816-0913
