What is the best way to mount your fuel pressure regulator to the fuel log? Install it before the fuel log with the log sealed at the other end allowing only the regulated fuel to go through the log to the carb or put the regulator on the far end of the log allowing the excess fuel to return after it goes through the log.
Fuel pressure regulator
I also had a similar question, I'm facing this problem with my axis car and looking for suggestions and recommendation plz if anybody know solution of that, Than share with us.
I've been on a kse pump for a while so I might be wrong.The reg. that bolts to the back are bypass regs. with return lines .The one that goes to the front of the log doesn't need a return line.Depends which one you have on where to mount it.
exactly correct on above post
you first need to know what style regulator you have and then ask the question
they look the same but are not
