Just got into racing. Bought a pretty fresh 604. Timing cover warped and leaked oil first night out. Pulled motor took it to NeSmith rebuilder, waited a 3 weeks for repair, ran it maybe 50 laps and rear main or oil pan gasket is now leaking. Do you guys have this much trouble with these engines leaking? I've kept a close eye making sure it's not overfilled.
604 leaking oil.....again
Make sure your crankcase is venting properly. Check your left valve cover breathers for obstruction, something could be crammed down in there that might not be obvious at a glance....
have never had a rear main oil leak-----more than likely it is the pan
when they changed the cover they had to have the pan off---did they change the gasket?
the comment about breathers is relevant but more than likely not the cause-----but i would like to add to the breather comment and ask if you are running shielded breathers? and are you facing the shield toward the front of the car and the fan blade, like it is suppose to be?
try tightening the pan---might help
brad
