Header bolts
    Header bolts
    Anybody ever tried using studs instead of bolts?
    Just seems like it would make it easier to line everything up when putting them on.
  • dirtracerl77
    • 89
    Normally the head of a header bolt is much smaller than a nut would be for a stud. There is not enough room on all the tubes to use a 9/16.
      Yeah...you're right. And even if it would work it would be next to impossible to get a turn on a wrench. Oh well...
      • collateralDamage
        • Jul 2010
        • 110
        i like using header bolts with a 5/16" head - like schoenfeld 3006-12.
        • parocket
          • Feb 2010
          • 69
          We use a combinations of studs and bolts, I think 1 bolt on each side otherwise studs. Easier to tighen and makes install simple.
          • drtrkr25rjr
            • Apr 2015
            • 5
            ARP sells 12pt 3/8 nut that only takes a 7/16 socket or wrench.
            • zeroracing
              • 1014
              I use a combo, makes it easier.
              • 75fireman
                • 411
                Stage 8 locking fasteners Make a 12 point low profile with locks very easy to use and when you use the locks they never come loose
                • Lizardracing
                  • 839
                  Allen headed cap screws from the local hardware store.
                  I made tool just for this reason. I used a ball type 3/8 allen wrench and cut off the short side 'L' leg. Then welded a 3/8 drive socket on the Allen wrench. It could have been used as is but I went a step further and machined a diamond knurl into the shank for grip when starting the bolts with one hand and holding the header with the other.
                  • hites2204
                    • Feb 2015
                    • 2
                    I use the 5/16 head bolts and put red high temp silicone on the threads, never loosened up more than a half turn all season.
