Oil cooler lines
  • ABBIENORMAL
    • Oct 2014
    • 8
    Oil cooler lines
    Hey guys, what size of oil cooler lines would be best for the 604, AN8 or AN10?
  • MM90
    • Oct 2010
    • 422
    #10 would be the smallest I would go. #12 is common for oil lines on dry sump stuff and that's also what I use on my external oil pump engine.
    • brad hibbard
      • Oct 2007
      • 974
      agree 100% with MM90
      -8 is a recipe for disaster
      -10 is acceptable IF everything is perfect--using all high flow fittings and nothing over a 45 degree angle
      -12 gives a window for some in perfection in design---still use all high flow fittings but go ahead and use them 90's
      I know it seems like a huge line for the application and thats what I thought in the beginning but after working on crate engines for a day or two I have found -12 to be the best choice and is what is on 100% of our engines that have oil coolers
      as ever
      brad
      • ABBIENORMAL
        • Oct 2014
        • 8
        Thanks guys, greatly appreciated. I was thinking the 10 but now I know 12 is the better choice. Thanks again
        • 75fireman
          • 411
          I have no10 on ours straight fittings oil temp runs around 225 having no problems but you can trust Brad He will not steer you wrong
