604 carb jetting
  • dirtrace09
    • Aug 2007
    • 746
    604 carb jetting
    Have a friend who is running rich with a 750 holley carb on his 604 on pump gas. Curious where most people jetting their carbs running pump gas?
  • GRT62
    • Jan 2014
    • 177
    73 front and rear
    • brad hibbard
      • Oct 2007
      • 974
      make sure it has power valves front and rear
      jetting is hugely affected by other orifice sizes within the carb----IF this is a "box stock" holley with front and REAR power valves then I will agree with the above poster
      as ever
      Brad
      • dirtrace09
        • Aug 2007
        • 746
        Thank you both. This is a racing holley carb with power valves. He is jetted a lot higher than that right now. I will jet it down. Are most running a 6.5 power valve?
        • brad hibbard
          • Oct 2007
          • 974
          all Stealth carbs come to us with 4.5's
          the number (rate) of the powervalve is where it releases in relationship to vacuum
          manifold vacuum holds the valve closed----keeping the mixture lean and clean at low rpm
          4.5 valve will open at 4.5 inches ov vacuum----a 6.5 would open earlier as the vacuum would only need to drop to 6.5 inches before it would open
          the lower numbers will keep you clean a tick longer----not a huge deal---dont stay home because you think your powervalve rate is wrong
          staying with "High Flow" valves and greasing the gasket on installation is important though
          as ever
          Brad
          • W2racing
            • Dec 2010
            • 53
            as ever
            Brad
            Greasing the gasket????
            • hatchet
              • Nov 2011
              • 46
              I use cherry chapstick on the gaskets so they dont stick to the metering block and the bowl . Grease will do the same thing so in the heat of the moment you dont have to scrape the stuck gasket off and reuse the gaskets .
