Car just isnt hiking on entry. Not running a LRF shock, could this be part of the problem? 1/2 mile race track, Black front rocket 2007. 450Lf, 375 Rf, 200 LR, 250RR(Going to a 225). J bar center on pinion, 8 3/4 on frame. Both bottom bars are up. Have the RR trailed 3/4". Car is just flat on entry and pushing but as soon as i pick the throttle back up, the LR will hike and go. Rf is probably 1/4 inch from bottoming out.
No hike on entry?
Is the track rough or smooth? I have an 09 black an i have to be in the 300 or 275 rsnge on rf to get any attitude in car if u get down there youll be ok
If you are dumping the gas the lr. might be coming down . More lr. compression would help . Try to trail brake and feather the gas will keep the right front down and the left rear up . Takes time and practice to get used to it . Might have to adjust brake bias to what you and the car like .
Track is glass smooth. Track was super heavy when i had this problem. Thinking this issue was the LR shock mount was too low(away from the axle).
